1984 Contessa 2850 Flybridge duo prop size
    Hello all,
    I tried to social distance this weekend and looked forward to seeing how my new props would increase performance. At the recommnedation of my mechanic and posts on this forum, I just changed my duo prop from a set of B3's to B2's, First run was yesterday out of Bellingham Bay. Fully loaded, fuel, water, kids etc. I could reach 4200 rpm not 4400 rpm WOT. On the B3's I could also reach 4200. I cruised at my usual 3600 rpm and was at 14 to 15 knots on the GPS, with the B3's I would be at 19-20 knots. Is the change in props showing a different issue with my engine? I had to run at 3800 to maintain 18 knots, to keep Admiral happy entertaining 3 boys under the age of 11 years old. Also fuel consumption was high, I usually burn about 60 gallons, I am guessing I burned 75 gallons. I will know more tomorrow when I fill up. Hull was reasonably clean per normal use.
    Specs
    AQ260A with 280 duo prop
    Marine Electronic Distributor (old prestolite 65-190)
    Any thoughts? On the bright side we saw a pod of orcas in San Juan Channel on our way to Roche.
    Thank you,
    1984 Contessa Command Bridge
    AQ260a
    VP 280 duo prop
    North Puget Sound
    Squalicum Harbor
    The difference of the props is absolutely a problem. The original set was more correct for your boat because it’s reaching the proper wide open throttle rpm that it should.
    I’ll admit right off that I don’t know the difference, and the sellers on line that I found in a quick search don’t tell me the pitches in each kit, but what you are describing is an over prop, meaning the prop has too much travel in each rotation so the engine is working harder to spin the prop. With your normal cruise rpm and the b2’s I think you are getting a lot of slip because the push from the prop wash isn’t enough to get the boat into the correct planing configuration. I’m guessing that you were stern heavy at 14kn. This is where the wizards and mystics earn their money. The information you've obtained from all of the sources is gold. You have something peculiar going on with your boat. It could be loading and storage, where and how things are stowed, or the runoff from the creek from Lake Watcom.
    That higher fuel burn means you were probably opening the secondary on the carb. Kinda like going into passing gear. Btdt
      I ran B3 on my 85 Contessa Command bridge and would get about 20kn at 3500. Never really got to 4500 like it should when loaded up. I watched for B2 set but never found one to try.
      Nobody gets out alive.
      • NWEricson
        NWEricson commented
        Yes this what I get with the B3s.
      I have B2 which I found to be better than B3 that I am able at get 4400 rmp. Attached is my boat speed (blue) and fuel usage (pink) chart.
      Joe
      1986 2850 with duo prop
      Click image for larger version  Name:	image002.gif Views:	0 Size:	7.2 KB ID:	566669
      1986 2850 Commend Bridge on hydrohoist
      A260 and AQ280 with DP lower unit
      • NWEricson
        NWEricson commented
        This is what I was expecting!
      Something is wrong!
      The Duo Prop drive ( with a healthy and well tune engine, hull clean, and of the correct reduction) will offer a 25% to 35% performance gain.
      Have you verified the following:
      .... 1.95:1 reduction
      .... fuel delivery system working as it should
      .... good cylinder pressure readings
      .... ignition advance at/ near 28* @ 3,200 RPM
      .... location of set pin
      .... is the hull stern heavy
      Rick E. Gresham, Oregon
        Originally posted by 2850Bounty View Post
        Something is wrong!
        Bounty,
        This was not a swap from single to duo, I only changed the props from b3 to b2. As a scientist I wanted to limit the change in variables to one, the prop, all other variables were kept the same, weight, fuel amount, water tank amount, empty holding tank, number of batteries, oops I did change a second variable I had the three kids total 200 pounds extra.
        1. The casing is stamped with 1.95:1 on the lower unit. Is there a way to test this?
        2. I will check fuel system. It is a mechanical pump. I can hear the rod taping. Fuel filter changed last year.
        3. I will check cylinder pressure. When I purchased the boat the mechanic told me the engine pressure was good. Did not give me numbers.
        4. I will check advance. I have not given the engine a proper tune up since I purchased the boat two years ago.
        5. I have not changed the set the pin since replacing the transom shield three years ago. Would I need to change the setting with B2's?
        6. I was not anymore stern heavy than usual, we carry the inflatable on the swim step weaver davits. I could run without the inflatable?
        Thank for everyone for your help, as I work through the diagnosis.
        AQ260a
        VP 280 duo prop
        North Puget Sound
        Squalicum Harbor
          Elaborate on #2 You hear the rod tapping?
          "THE FIX"
          Misc. projects thread
            Scares you doesn’t it after you blew a hole in a piston? Should not be any tapping noises.
              I’d assumed the pushrod for his mechanical pump is making the noise. Yea don’t think that’s normal😳
              "THE FIX"
                I am sorry I should have been more clear, the fuel pump connect rod or push rod to the cam.
                This sound started over the winter for the first few minutes after startup I could hear a tapping sound, it would then go away or become to faint to hear. I used my stethoscope and located the sound was coming from the fuel pump connect rod and not through the valve cover, exhaust or stern drive. I could hear the tap through the intake manifold and the loudest at the fuel pump.
                Kind Regards,
                AQ260a
                VP 280 duo prop
                North Puget Sound
                Squalicum Harbor
                  Originally posted by NWEricson View Post
                  Bounty,
                  Are you running the B or C series props? Are they a matched set? The two must be a matched pair.
                  Yes. With the transmission's sliding sleeve locked into the gear cup, the engine will rotate 1.95 times to 1 prop revolution.
                  Once you begin this test/check, you cannot let up..... you must keep the sliding sleeve and gear cup engaged.
                  By "fuel delivery system" I was referring to the carburetor.
                  This will be important.
                  No! Center hole works best.
                  Are you using large plane trim tabs?
                  • NWEricson
                    NWEricson commented
                    If they are not a match set, is there a way fix this or do I need to buy a new set?
                  #1. Running B series. They are not a matched set. I purchased from the Prop Shop Mukilteo, WA ; FWD prop is used as they did not have the rear pair so they sold me a new rear. Shouldn't they have known they need to be match?
                  # 2, 3, 4 - I will be getting down to the boat and will check on all three.
                  #5 - We will be pulling the boat in two weeks and I will check.
                  #6 - I believe they are the 12x12. I never had a problem getting up plane until last weekend, I only use the tabs for port/stb trim.
                  Again thanks for the assistance.
                  AQ260a
                  VP 280 duo prop
                  North Puget Sound
                  Squalicum Harbor
