Interesting Oil Wipe Towel
    https://youtu.be/J8UPJ0igQF8
    I know paper towels soak up oil but I have not seen a specific designed for it. Anyways take a look at this video and you’ll see a cheap way for soaking it up if your bilge gets funky
    FWIW, I found “Oil Pigs” to work better for me. https://www.newpig.com/absorbent-mats/c/100
    I bought a 75’ roll of it that finally ran out after three years and immediately bought a new one. I keep a strip of them under the engines and keep a couple folded in the keel.
      Driz, this appears to be the same absorbants found at most marine fueling stations to clean minor diesel spills. I do use these under both of my engines to 1. Catch any oil, 2 Since they’re white any new oil leak is quickly indentified.
      Jim Gandee
      1989 3888
      Hino 175's
      Fire Escape
      [email protected]
        these have been around for years and can be purchased at almost any autoparts store or anywhere they sell oil.... oil absorbent pads, sometimes also called oil diapers.
        take 2 or 3 of them and roll them loosely into a small tube, and secure it with string and throw it in the bilge.... any oil drips will be absorbed into the pad rather than being spread around the bilge
        a person can buy the rolled pads at the marine store for the same purpose (throwing in the bilge), but at 15-25 dollars for 2 or 3 rolled pads, ( https://www.newpig.com/pig-water-hog...yABEgLyfvD_BwE ) if you were to buy a whole package (100 pcs.) for 30-35 dollars, you could roll your own "pigs" at a cost of about a dollar.... which makes you feel better about changing them out more often...
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
