2556 random projects 6/10 headliner
    The monkey fur was in a sad state in the bow cabin so decided to replace it. Will use a about 3mm thick soft vinyl material glued with contact adhesive. Removed old fur and removed most of the old adhesive. The surface is not 100% smooth so the end result will not be 100% prefect either but good enough for me. The roof i will steam clean only, to renew that is too much work for now.
    Click image for larger version  Name:	IMG_20200117_214731.jpg Views:	0 Size:	244.2 KB ID:	557658Click image for larger version  Name:	IMG_20200117_214430.jpg Views:	0 Size:	282.6 KB ID:	557657
    Bayliner 2556 1990 project
    Was running out of hands and space with the vinyl...so did it the wrong way. Started gluing from the lower end to keep the sheet in place, and worked up in about 30 cm segments, took some Click image for larger version
ID:	557663Click image for larger version
ID:	557662Click image for larger version
ID:	557664Click image for larger version
ID:	557665 time with the drying time. Worked well in the end, no major wrinkles or bubbles.
      Looks good to me!
      Jeff & Tara
      (And Ginger too)
      Lake Havasu City, AZ
      2000 Bayliner 3388
      "GetAway"
      Cummins 4bta 250s
        is this vinyl foam backed?
        1998 Ciera 2855, 7.4L MPI, Harbourfront Toronto, Ontario
          Nice job, did you ventilate the space
            Thanks. I don't use any separate foam this time, its only a single product, pretty soft foam with a vinyl surface that is little harder so its cleanable. The question about ventilation is good an valid. The glue used is bison tix. As i have to protect the "construction site(the boat)" from weather and wind with tarpaulins, not that much natural ventilation. So I have, basically all time spending inside, a vacuum cleaner running. The cleaner is located outside, then i have a cyclone and a long hose. So where ever i work inside the boat, i always keep the hose nearby. That will suck out dust and fumes, and the replacing air is clean. Works extremely well. In addition i use the 3M full face with dual filter, P3 filter and the carbon one.
            Living room floor is handy for boat jobs Click image for larger version
              Yes big shop vacuums are the ticket. You will up the value when completed, great job.
                Heated the hull from outside as also tried to keep the bow cabin slightly isolated to keep close to +20 degrees inside for contact adhesive work as also painting. Used white International Danboline bilge protection paint. Oh man the fumes...forgot the vacuum on only half speed so air change was not good enough in the small space. The paint covers very well, but on some spots need to do another layer. Did not yet paint the most upper surface of the bulkheads as need to step on it getting in and out through the hatch Click image for larger version  Name:	IMG_20200126_184510.jpg Views:	0 Size:	162.0 KB ID:	558095Click image for larger version  Name:	IMG_20200126_184538.jpg Views:	0 Size:	100.5 KB ID:	558096Click image for larger version  Name:	IMG_20200126_184548.jpg Views:	0 Size:	94.9 KB ID:	558097
ID:	559414Click image for larger version
ID:	559415Click image for larger version
                  Not sure will I cover this are with carpet , vinyl or maybe only paint. Thus wanted to smothen it out a bit as also fix the floor as it was far from even. Sanding, then some filler, cloth + epoxy and then filler again.
                  Not ready yet....
                    Nice job, I would opt for carpet.
                    Carpet...hm.... then all this is in vain.... Lets see, have really not decided yet, anyway its always easier with somewhat straighter surface. It was all very rough after removing the carpet. Will probably only epoxy prime it as a first step when ready with filler and sanding.
