Adding generator and cabin heat
    I just bought 1987 2850 Contessa Command Bridge with twin OMCs. I want to add cabin heat since the boat will be used on Minnesota Canadian border. Choices seem bring a portable generator on swim platform in which case has anyone done this and exhausted underwater to quiet? Option two, find marine gen that fits. Where does it go? Then I could use electric heaters. Or three, add a gas powered cabin heater. In which case, has anyone got some install or purchase hints? Seems the generator is easiest sine I get other benefits like adding portable AC for rare need or pizza oven use, etc. Ideas? Oh, I am quite handy.
    You can put a red dot heater that is connected to the closed cooling system and is basically a car heater. As to adding a generator, a good permanent installation takes up a significant amount of space. Having a portable on the swim step is okay, but surprisingly loud.
      I saw a guy do a very clever job adapting a "parking heater" (google search it) on his boat for winter months. For under couple hundred you can have a miserly diesel furnace "parking heater". Truckers use them.
      Tony Bacon,
      Washougal, WA
      Caspian
      1997 3788 Twin Cummins 250hp
        Like Pete I’d run cabin heat from the closed cooled system if equipped. Onboard genny can be costly
        "THE FIX"
        Misc. projects thread
          Here’s Landins diesel heater install:
          https://www.baylinerownersclub.org/f...llation-diesel
          "THE FIX"
            No way a built in genset is going in a Contessa bilge if it has twins.
            Nobody gets out alive.
              A Planar 44D diesel forced air would probably the easiest install rather than plumbing long cooling lines. Engine heat only heats when running. As a temporary fix a MR Heater propane heats my 2859 nicely. Its a moist heat though. The Planar is a nice dry heat.
              "REEL WILD"
              2001 2859 FNM 300 Diesel-Bravo 2
              Anchorage, Alaska
              If you don't like the weather, wait 15 minutes.......
                Are you wanting heat while under-way and/or with engine operating only.... or, are you also wanting heat while at anchor without engine operation?
                A portable generator will not be capable of using a wet exhaust system.
                As said, it is very doubtful that you'd be able to fit a True Marine Generator into this hull with twin engines.
                Only if the generator was capable of producing enough Watts. (resistance heat is Watt hungry)
                I would suggest that you consider the diesel heater, and then find a location for a small diesel fuel tank.
                Rick E. Gresham, Oregon
                  As others have mentioned, a forced air diesel heater, with a dedicated fuel tank may be the best alternative. The space on your boat is limited. A couple of locations that will allow for a high enough exhaust are under the helm seat, or in the mid-berth area. I recommend that you take combustion air from outside, rather than from inside the boat. This is more important on a gasoline-powered boat, since you do not want any gasoline fumes getting into the heater's combustion chamber.
                  I recommend a Webasto heater from Sure Marine in Seattle. They have awesome customer service and very knowledgeable techs. This help may come in handy as you plan and install the heater.
                  2013 Boston Whaler 130 SS
