New Gauges For Old Bayliner
    Can anybody tell me where I can find gauges to replace the old ones on a 1984 Bayliner Capri (w/ 4cyl. engine)? I'd like to replace all of them - tachometer, speedometer, fuel, volts,temp & oil pressure. Thanks.
    Here’s one option, there are others.
    https://www.overtons.com/search?q=Ga...s&lang=default
    Welcome to the club😁
    "THE FIX"
    '93 2556
    Misc. projects thread
      Thanks. I was hoping there might be some exact correct replacement available but it looks like I will have to choose some aftermarket gauges.
        Have you tried Great Lakes Skipper? They seem to have a lot of older style gauges in stock.
        Peter Walter-Smith
        Riverport of Goolwa, South Australia
        2014 Bayliner Element XL
        115HP Mercury EFI
          I wound up going with a set of Faria Gauges. Faria "Chesapeake" SS 6-Gauge set. They were a perfect match for my old gauges, plugged right in! Everything works. I actually ordered these from Amazon as they offered the lowest price and fastest delivery. Thanks to all your input tho.
            New gauges really make the boat “your own”...I swapped out my OEM tach for one that has an hour meter. I also swapped out the the white light bulbs with blue LED’s and just added the GPS speedo, which is a close match to the other gauges this past summer as my speedo never worked.. Click image for larger version
ID:	557224Click image for larger version
ID:	557225Click image for larger version
ID:	557226Click image for larger version
ID:	557227Click image for larger version
ID:	557228Click image for larger version
ID:	557229Click image for larger version
            Lake Hartwell, GA
            2012 BR 185 - 3.0 TKS
            1987 SeaRay 300 - Twin 454’s
            1995 Yamaha Waverunner III GP
            1996 SeaDoo GTX
            1999 SeaDoo GTX
