Prop siezed on
    Prop siezed on
    How do I get my propeller off? Spun the hub on the weekend and it won't come off. Any tips please?
    David
    1999 Bayliner 1750 Capri. 3l Mercruiser Alpha
    2014 Yamaha VX Cruiser
    It was a lot of years ago for me, but I had the local shop remove it because I didn’t have the right tools. What they did was heat the heck out of the prop hub while standing to the side. When the prop lets loose it goes flying. Then they cut the hub off. Hack saw and chisels.
    The problem is the hub rubber bushing absorbs any puller action and/or hammering.
    • Davidlyne
      Davidlyne commented
      Maybe I need to take it to the shop.
    Hey all you mechanics out there...…..Couldn't you, with patience, use a grinder or even a Dremel tool to carefully cut through the 3 layers.....prop/rubber/metal core?
    It might take an hour, but I bet it takes at least an hour to make 1 round trip to the shop just to drop off the boat......and then another hour out of your life to pick it back up.
    • Davidlyne
      Davidlyne commented
      Yes, I could do that, just trying to get advice from someone that has done it. I don't want to destroy anything, other than the prop
    If the shop takes it off with heat it can be rebushed. I changed to the GRP sleeves and never spun one again, nor did I significantly damage one. My previous boat was in brackish water all year and the rubber hubs would fail annually.
    When you install the new one, coat the splines with anti-seize then take the prop off every year or so depending on how long the anode behind the prop typically lasts.
      When you finally get it off coat the prop shaft with Evinrude Triple Guard grease and you’ll never have that problem again. I’ve used it for years on a boat used in salt water for a six month season.
      Long Island Sound Region
        Thanks for the replies. I am going to see how I go getting it off on the weekend.
        David
          UPDATE for those that replied. It is OFF. Soaked it for a week in penetrating oil, modified a gear puller and off it came. Just ordered a new one.
          David
            Too cool!
              Congratulations. Glad it worked out well with no excess damage.
