3.0 WITERIZING PULL THERMOSTAT HOSE?
    hEY JUST LOOKING AT MY shop manual and it says pull thermostat hose of in the winterize chapter . I don't remember doing that . Is that the upper side or lower side and it gets reconnected right afterwards?
    Normally you remove the block drain plugs, poke em, and then disconnect the bottom end of the big hose that connects the thermostat housing and the front circulating pump. That will take care of draining the engine. Then you have to drain the exhaust manifolds and disconnect and drain the raw water intake hose. An inline engine will have one block drain plug and one manifold drain plug, a V6 or V8 will have one plug on each side of the block and one on each exhaust manifold.
    You need to post up what engine you have for more specific information.
    Long Island Sound Region
      What year is this engine? Does it have the quick drain hoses?
        2005 it has quick connects
          If this is what Merc calls a "single point drain system, do a Google search; "issues with Mercruiser's single point drain system".
          Read the negative aspects of it, and you'll probably convince yourself that you'll want to remove that system.
          Also, if you are tempted to use one of the Camco, Star-Brite or WestMarine winterizing kits, please read my Amazon write-up.
          https://www.amazon.com/gp/customer-r...at_pdctrvw_srp
          Rick E. Gresham, Oregon
            Get a nice set of picks and poke those holes good. Make sure water comes out of each one, if not find out why!
              I think you have the system with the two blue hoses that get unhooked and dropped into the bilge to drain the block. If so that's what I had in my 2003 Searay. I was instructed to drop those two blue hoses into the and to remove the hose from the water pump. This is the large hose that goes from the Thermostat housing for the the water pump.
              2016 Bayliner 215 Deck Boat
              Mercruiser 4.3 220 HP Alpha 1 Gen II
              2003 SeaRay 176 SRX Bowrider
              1988 Sunbird 170 Bowrider
              Evinrude 88 Special
              1970 Salem Skiff 13.5 foot
              1992 Johnson 40HP.
                However, if the hose attached to where the drain plug goes does not drain water, that is a problem! You would then have to remove the hose at the block and rod out the opening in the block to make sure it drains.
                  Listen to Rick and others. The problem with a quick drain is if one is clogged with sand and no water comes out, how do you know that. Personally I want to see each drain actually have water come out. Thus poking the drain to get any sand flowing. My friend lost two engines not doing this. He powered loaded at the end of the season and got sand in the blocks. His fall lay up was perfect. The spring, not so good. He didn't probe the drain to be sure water came out.
