Flat spot in throttling......
    I guess that would describe it.....
    Here is the symptoms of a 1996 3.0LX mercrusier.
    She starts fine, wait for choke to open, then shove off.....
    I can't get a smooth acceleration nudging up the throttle, at about 1500 RPM she acts like she wants to stall......I just give her more throttle, she jumps, but then I have to pull back on it, or I will nose up too much, etc....
    Now coming down from higher RPM's after running, she will do the same thing in that RPM range....not fun when I am approaching the dock, I have to idle down sooner than I would like, and if I have wind and current, I'd like more throttle to work with, but at a steady output, not having to "jimmie" my throttle, in and out of gear.
    The carb is new, as is the fuel pump.
    I am sorta thinking my problem lies in the cable, which is the OEM from 1996. I just feel it should be smoother, I got a sense that the cable just might be binding in that range....???
    Is that a possibility?
    I just don't believe they would design a controller that is this "stiff"
    Anybody have any advice?
    I don't know if I can offer any good advice, but I'll throw my two cent explanation into the hat.
    With most any typical low fuel pressure carburetor, they will offer two fuel metering circuits.
    Low speed and high speed.
    These circuits rely on the Venturi Effect.
    The low speed metering circuit introduces the fuel from just underneath the throttle plates.
    These circuits offer an adjustable air screw.
    They will deliver fuel through this circuit while the throttle plates are in the closed position (idle position).
    They will continue to deliver fuel until the throttle plate position (as they open) can no longer create the necessary air flow past the discharge ports.
    The high speed metering circuit introduces the fuel from above the throttle plates via the air horns.
    With most carburetors, these circuits are adjustable ONLY by accessing and changing the main jets, and/or by adjusting the vertical needle rods, etc.
    During the transition from low speed metering to high speed metering, there will be what we call a "flat spot".
    Upon acceleration, the flat spot is eliminated by the action of the accelerator pump.
    Upon deceleration, there should be no noticeable flat spot.
    By the way, the accelerator pump does not function during the transition from open throttle to closed throttle.
    If the accelerator pump is working and is synchronized with the throttle plates, it should eliminate any flat spots during the transition from low to high speed metering.
    Now, if the float bowl level is low, the high speed system may lag behind a bit due to difficulty with the Venturi action.
    It may also do the same during the deceleration transition.
    I'm just tossing this out there..... it may be a float level issue, or it may be something completely different.
    Rick E. Gresham, Oregon
    • Island Eddie
      Island Eddie commented
      Thanks Rick, that was very informative....heck, I think I even understood it LOL!
    Idle mixture might be too lean.
      The GM 3.0Ls are prone to "run-on" or "dieseling" when this mixture is too lean.
      Eddie has not mentioned that!
      Good point, though!
      • builderdude
        builderdude commented
        And the idle mixture only effects the idle circuit, sounds like his flat spot is well beyond that.
      AH.....I have noticed a few run-ons after a healthy run at cruising speeds. I tweaked the carb down thinking I didn't want to put any unneeded pressure on the clutch dog....
      They say true adjusting needs to be done in the water, under a load....I just tried to guess. Perhaps I should follow the advice in the manual next time out and see if that solves it.
      Take it to a lake, I don't like working on a motor running, in bumpy water
      THANKS guys!
        What pressure is the fuel pump giving you ?
          That is refered to as "run on" or "dieseling", and is caused by:
          .... higher than normal operating engine temperature during shut-down.
          .... lean low speed fuel/air mixture during shut-down.
          .... carbon build up on piston decks/combustion chamber.
          It is NOT caused by ignition timing. Ignition is CUT during shut-down.
          to avoid:
          .... fatten up the low speed fuel metering.
          .... give the engine a few minutes to cool before shutting down.
          .... shut down while in gear.
          That would be for adjusting the SI or SA system.
          When the engine is being shut-down, you would be in Neutral.... although some do shut-down while in gear to reduce RPM and to lesson the likelihood of run on.
            I do not know...how should I test this Chief? What am I looking for?
              I doubt that would be part of your issue.
              If fuel pump pressure was on the light side, you would experience problems while out cruising.
              If fuel pump pressure was on the heavy side, and if the carburetor's needle/seat was not holding, it would cause a rich scenario while idling and during shut down.
              Rich scenarios do not typically cause "run on" or "dieseling".
                No, she runs great at cruising speeds, starts up fine, etc...great fuel consumption, never backfires or miss.....holds its RPM.
                  Looking for 4-7 psi no more no less. Maybe float is a little low,
                    Me thinks you need to rebuild the accelerator pump. Sounds like the throttle plates open without the accelerator pump being able to keep up.
                    "THE FIX"
                    Misc. projects thread
                      Could be the pump. Thought I read new carb.
                        New carbs aren’t always plug n play. My opinion is low fuel pump pressure would cause more issue at cruising rpm.
                        "THE FIX"
                          Yes, its a new professional rebuild, I have the old one I rebuilt too, which I did put on, it worked, but I caved and put the new one on trusting it more than me....????
                          Can I test this without pulling it all off?
