Merc Tubitious - 5.0L (305) Bypass Pickup HELP
    I know this has been discussed in other posts, but not necessarily as I am looking to do it. It looks like I need to put in a thru hull water pickup to bypass the Merc pickup hose in the lower unit to cool the engine. Looks like I have tubitous. Anyway, I’m looking for some help with a parts list (size of thru hull w/scoop, strainers, hoses, etc).
    Thinking of putting a “T” in place to leave the original pickup hose in place and working to help cool the drive rather than putting on a shower. Thoughts on this? Also would like to put in another “T” so I can fresh water rinse it from the “T.” If you have a pic of your setup along with the parts list I’d appreciate it.
    Thanks.
    "Relax Inn"
    2012; 255 SB Bayliner
    Venice, Fl
    prior boat:
    2011; 180 BR
    Tubitious? you mean Bravoitis? You have a Bravo?
    if so it’ll be 1 1/4” through hull & strainer etc. there’s a slick through hull to aid in the flushing via a garden hose.
    "THE FIX"
    Misc. projects thread
      Hey Dave - Bravoitis, tubitis same thing. Guessing you may have done this to your 2556? Anymore info would be appreciated esecially pics. And yes Bravo III with all the emission systems.
      "Relax Inn"
      Venice, Fl
      prior boat:
      2011; 180 BR
        I have not added the through hull or strainer. I simply repaired the Bravoitis condition during the rebuild of the gimbal housing. There are a few here that have made the conversion though. sketch, and lineman being the most recent I think. The pics in those threads may have vanished into a black hole during our last upgrade. If they don’t see this maybe sent out a couple PM’s
        "THE FIX"
          Here’s a pic I found of Doug’s 2452 with the added through hull and strainer including his DIY flush T.
          "THE FIX"
          • FredK
            FredK commented
            Is Doug still on the forum? The thru hull looks like it is in front of the engine, then to the left looks like a "T" for a flush valve or hose, then the strainer and I assume the other side goes to the sea pump. How would I contact Doug?
          Yep that’s how it’s plumbed. Haven’t seen Doug in quite a while but maybe send him a PM
          https://www.baylinerownersclub.org/m...-go-aweigh2452
          "THE FIX"
