Fuel Cooler/Pump
    Fuel Cooler/Pump
    Hi Folks,
    I have a leaky water and fuel assembly. I just priced it all and its around $1600 can for the complete assembly.....wow. Anyone have this issue? Any other options out there?
    Engine/year?
      Are you referring to Merc’s combination seawater pump/fuel
      pump?
      https://www.google.com/search?source...3A8lFXICL8zkM:
      If so, you may have an option of going with a Johnson crankshaft pump and then mount the mechanical fuel pump directly to the cylinder block. This will eliminate the issues with belt driven pump.
      Rick E. Gresham, Oregon
        pump?
        From my knowledge Merc only used the combo unit on 7.4L engines that do not have the provision for a mechanical fuel pump so an electric fuel pump would be required if changing to the Johnson crank pump.
          Yes sorry. Its a 1999 2855, 7.4L. See the pic of the unit we removed.
            Cool fuel electric pump assembly. Yup not cheap.
              Where is it leaking?
              water tube might be rebuilt by a good radiator shop. I'm guessing but these things are basically a mash up of a GM high pressure fuel pump ( the kind found in the gas tank of your chevy pu) and that heat exchanger. And yes mercuiser is way to proud of them.
              1992 2452
              5.0 alpha1 gen2
