No Raw Water Going Through
    Have a view of the video. No clue. The boat has been sitting for 4 months. Went to start it today, it ran, but couldn't get the raw water to flow. Took the pump apart, and it looks excellent, just like when I replaced it 6 running hours prior. Is there a seal or gasket between the lower and the upper units, that if it was missing, wouldn't allow the impeller pump to suck up water? Moreover, if there was one and it was missing, is the air leak below the waterline, such that the impeller would work? Can't figure out how this works in the water, but not connected to the hose.
    MMSI: 367637220
    HAM: KE7TTR
    TDI tech diver
    Kevin
    When we fire up on the garden hose and water muffs, once the garden hose is supplying water, the muffs will typically leak water around the contact area.
    As the seawater pump begins to pull water in, we should see a change in the amount of water leaking around the muffs.
    In your video, I do not see a change in the amount of leaking water!
    Things to consider:
    is the impeller rotating (i.e., is it keyed to the shaft)?
    is it the correct impeller for the pump housing?
    is the lower gear unit's seawater path (to the upper unit) in good order?
    Rick E. Gresham, Oregon
      Originally posted by 2850Bounty View Post
      Things to consider:
      Yes.
      Yes, brand new Sierra housing, impeller, the works.
      That's my question. When putting the lower back onto the upper when I rebuilt the raw water pump seat, I didn't see a gasket between the two units, so I figured it was just up to the fit, and that where they join is below the waterline. But even then, wouldn't the water level just from the hose bring it up to the pump?
      We are taking it out in about 20 minutes to see if it will flush water through the heat exchanger. If it does, I'll be looking for a leak. If it doesn't, I'm back to square 1.
      Thanks, Bounty.
      MMSI: 367637220
      HAM: KE7TTR
      TDI tech diver
      Kevin
        Just to clarify:
        your saying it pulls water & everything seems to work as it should with no overheat or signs of anything wrong while its running in the water?
        But when attempting to run on the muffs it does not seem to pull any water and the temp will climb above the normal operating range to the point you shut it down to avoid any possible overheat damage?
        "THE FIX"
        Misc. projects thread
          its drawing submerged and not on hose, got mondo water shooting out a weep hole on the drive?
          You smear the housing with blue silly cone ?
            Originally posted by builderdude View Post
            Just to clarify:
            Just got back. That is how I thought it was, yes. However, it overheated, even cooked a little of the new paint. Then the 750GPH bilge pump clicked on and stayed on, though the water coming out was likely half the pump capacity. Apparently, it's not drawing while in the water either.
            What doesn't make sense is, the entire outdrive from just above the impeller was below the waterline. So, if there was an air leak, it would only have sucked water. Also, the impeller worked last time out, 4 months ago. If you recall, I did a major on the engine then, with new risers, exhaust manifolds, oil pan, had the engine removed, fully serviced the upper and lower, ....
            On the muffs, nothing came through. When I opened the pump, it was full of water. Yet, while running the engine, the only water coming out was leaking out the muffs. No water escaping inside, out the bottom of the OD, nor out the bilge drain. It's like there is a massive blockage somewhere. But where? I've been all over the diagrams, and can't see anywhere where that could happen.
            .....Just when I'm prepping to sell it.
            MMSI: 367637220
            HAM: KE7TTR
            TDI tech diver
            Kevin
              Others with the cobra drive will need to chime in as I’m not familiar with OMC stuff. There definitely lots of water getting into the bilge area so I’d start investigating there.
              "THE FIX"
                Same as a merc, y pipe etc.
                Thru hull is clogged maybe, see the hose that enters from the transom follow it to its first stop could be the power steering cooler, port side under the mani maybe remove hose back wash that hose with garden hose you might have to shunt the hoses together, do this with the drive off.
                Have someone watch what comes out.
                  The cooler is okay. Not sure about the seal where the raw water enters through the OD. I did repair it, but it may not have fixed the corrosion issue. Maybe my patch broke away. Guess I need to remove the OD and see what's up.
Name:	Cobra Adapter In.jpg
                  Thanks.
                  MMSI: 367637220
                  HAM: KE7TTR
                  TDI tech diver
                  Kevin
                    My thoughts/comments via post #7:
                    I’m not familiar with the impeller set up in the upper unit on OMC but with the amount of water you had in the bilge I’d guess the impeller could be doing its job and a hose has possibly let go in the engine bay or similar.
                    "THE FIX"
                      Looks like I'm in over my head ...again. Since Chuck of Olympic Marine closed his doors last January, anyone know of an OMC mechanic anywhere near the WA Olympic Peninsula?
                      MMSI: 367637220
                      HAM: KE7TTR
                      TDI tech diver
                      Kevin
                        Take the hose off the cooler or the stat housing backwash the drive see what comes out. It's free .
                        No one wants to work on Cobras, they don't know them as some old farts on this site like me.
                        Dont want to listen so be it, getting grumpier as the years tick by.
                          Did that. Even took the lower off to see if there was something plugging it. Everything is as it should be. Only thing that makes sense is the pump isn't creating a vacuum. I just ordered a complete pump; housing, impeller, seals, cup, backing plate and gaskets.
                          MMSI: 367637220
                          HAM: KE7TTR
                          TDI tech diver
                          Kevin
                            Get the blue silly cone, seal the outside of the housing, the split, the bolt holes, make sure get the tube inserted.
                            Damn I just read my last post, really am getting to be a grumpy old man
                            Post back !
                              New impeller pump and housing finally arrived. Just installed it, connected the water through the muffs, and fired it up.
                              There is a sprinkling of water flowing out the OD, (unlike previously) but none out the prop.
                              Brought it up to temp. Using an infrared temp gun, the top of the STB riser reads 123F, but the port riser is over 160F and gradually rising. There is also steam coming out of the prop, but no water. I shut it down.
                              I took the port hose off where it enters the front of the exhaust manifold and fired it up. It has a good flow of water coming out. I shut it down and reconnected it.
                              I restarted it to fill the exhaust manifold, shut it down and removed the exhaust drain cap. The exhaust housing was full.
                              So, this somehow has to do with water not getting over the riser. Yet, it appears to have a good flow. Now what?
                              MMSI: 367637220
                              HAM: KE7TTR
                              TDI tech diver
                              Kevin
