Gelcoat or painted with awlgrip-gctid417672
    I have a 1988 Bayliner Capri 2150. Just wondering if the hull was painted with awlgrip or gealcoat? The rear of the boat is peeling...looks like the clearcoat is coming off. I didn't know if boats had a clearcoat.
    I have a 1988 Bayliner Capri 2150. On the back on the boat its peeling like the clearcoat is coming off. Is that a clearcoat, gelcoat, or awlgrip? Thx
      Gelcoat usually doesn't peel. It cracks and chips. If it is peeling, it is most likely paint; and if it is clear, you may be a victim of some really bad attempt to give the boat a shine. We had a member mention he bought a boat sight unseen and realized the entire hull (above the waterline) was coated with polyurethane in an attempt to give the boat a shiny appearance. I hope you are not finding yourself in a similar situation. Do you have any pics of the area you can post?
        I can post some pic this afternoon. Thx for the info
          Painting a hull, IMO, should be an absolute last ditch effort after exhausting gel coat restoration attempts.
          Rick E. Gresham, Oregon
            They'll often shoot clear gelcoat into the mold before the first color coat, but that usually only on high end boats. There are a number of clear coat systems you can buy to bring the shine back on a more vintage model. You're probably looking at something like that on yours that is starting to let go.
            iBoatNW
              Probably VertGlas or Polyglow. It was on a boat I had, looks just like skin flaking off after a sunburn. That stuff needs to be recoated every year or so.
                If that is what it is what do I need to do, wet sand whats left the re aply the clear gelcoat. Then polish and wax and buff?
                  Wet sand-buff and polish and wax, forget the clear coat it will not be necessary.
