I have a 1987 38' bayliner, just spent the weekend and when we went to get it pumped out
very little in the holding tank, there was some water in the bilge but my ac drains there the next morning the water was gone. But when we flushed the toilet i went outside and the bilge pump was pumping out sewage so i am assuming the holding tank is cracked. It appears to big to remove without cutting the floor, is it possible to use some type of bladder holding tank inside the leaking one. Any body that has had that problem with the 38 i would appreciate any help.
