Hi all
Doing some much needed maintenance, about to renew the bellows and gimbal bearing, read and watched all i can for usefull tips.
When i pull out the old lower shift cable, should i attach a new cable to the old cable inside and pull it through thus leaving it in the correct place?
I have a 2452 which has limited access down the back of the engine and am worrried that if i just pull the cable i might have issues pushing the new one through and into the correct position.
Special tools? Managed to buy a shift cable socket from california and getting it shipped over, reckon i will be able to manage without an expansion tool. The bellows ring tool, i will make from two pieces of 1/2" ply ( good tip there thanks), the only thing i'm short of is the engine alignment tool, silly price here in the UK and the shipping from the USA is high! Anyone in the UK willing to hire?
Anyone know the dimensions of the tool as i might be able to get it turned at an engineering shop etc?
Regards.
Regards.
