1989 KL 305 closed cooling mauals-gctid417126
    1989 KL 305 closed cool engine manuals
    Hi , Does anyone know where I can get owners manual or correct service mauals for a 1989 KL 305. I just purchased a 3270 and the only manual missing is the one for the engines. The only stickers on the engines are US Marine. I'm trying to find out from the factory who made the engines for them but they seem to be kinda lost. Thanks for any help.
    Tim
    Tim, US Marine used an array of GM V-8 engines. The transmissions could be from one of several manufacturers.
    Post a few a good photos of your engines/transmissions here for the guys to look at.
    Someone may be able to identify them.
    [CENTER] Rick E. Portland, Oregon
    Twin 270 HP 5.7's w/ Closed Cooling
      Not totally sure what you are trying to figure out. Is it the size and make of the engines?
      If so, look for casting numbers in the block. If they are GMs they are pretty easy to track, try:
      http://outintheshop.com/faq/casting/castings2.html
      There are many other lists as well.
      Chay
        Chay
        I know they are chev 305's...looking for a service manual for them but don't know if they were marinized by mercrury,omc or such..thanks
