Window shade clips-gctid350164
  • WorkerB
    If you are referring to the clips they use on mini blinds, I know Lowe's has them. They are way over priced and way too brittle but, I keep buying them.
    try your local RV dealer - the same clips are used for the blinds in RVs.
    Guest started a topic Window shade clips-gctid350164
    Can someone tell me where to get the clips that hold the shades against the window when the shades are down. Mine have a small nipple that clips in a hole in the bottom of the shade.
