5.0l feels like its running out fuel
    One of my engines will not stay running 5.0l 2 bbl carb. I just put the boat in 2 weeks ago and ran it a couple of times with no issues. Last weekend while the boat was at idle in neutral the engine stalled, it cranked a bit to restart but was ok after than and it ran fine on plane and at idle after that. Today I went to warm up the boat with the throttle opened a little bit to warm it up and I noticed the rpms were starting to drop slowly from 2k and finally the engine stalled. I was messing with it some more and it will idle for a few seconds and then the rpms just slowly go down again and it stalls. It will rev up fine when cracking the throttle, no hesitation at all and it will hold a 3k+ rpm but does fluctuate down a few hundred rpm and then goes back up and this is abnormal. After a few more minutes messing with it, now fully warmed up when I get to 2k pulling the throttle back slowly it just shuts off. It sounds like it is running out of fuel. Hard to restart also, need to pump the throttle a bit. I did not want to leave the dock to see if it will hold a load because I only had my kids with me and docking would be tough on 1 engine.
    The only thing I have tried so far is eliminating the tank and running it off of a gas can but it had no change in the way it ran.
    I don't believe there is an easy way to check fuel pressure, so I am thinking its a carb or pump issue. Does this sound like a fuel issue, coil?? I want to start to swap some parts form the good engine but would like some thoughts on what would be the best thing to try first.
    1999 3055, 5.0L, Bravo 2
    Have you changed your fuel filters? There is the spin on and one where the fuel line connects to the carburetor.
      Sorry the other thing I did check it the filter in the neck of the carb and it is clean. I have not removed the spin on fuel/water separator filter but do have one sitting here ready to change. I will do that as soon as I get a chance to.
        You have electric fuel pumps that get power from an oil pressure switch which can go bad. Sounds like a low rpm the switch is opening removing power from the fuel pump and the engine stalls once the carb runs dry.
          Mike, Is this switch separate from the OP switch for the alarm and gauge because the low OP alarm works fine. If it is a separate switch where is it and can I just throw a jumper wire in it to force the pump to run?
            Originally posted by vogs77 View Post
            Mike, Is this switch separate from the OP switch for the alarm and gauge because the low OP alarm works fine. If it is a separate switch where is it?
            Yes it is a separate switch. The alarm has its own and the oil pressure gauge uses a separate sender. The switch for the fuel pump should be mounted next to the alarm switch just above the oil filter block mount. If you have a remote oil filter it’s where the adapter is on the engine block.
              I am heading down not to look at that now, I do not have remote oil filter, it is still located on the bottom of the block.
                The fuel pump switch will have 2 wires on where the alarm switch only has 1 wire.
                  The newer version of that switch comes with a different plug but the new plug comes with the switch. Don’t get thrown off because it’s called a kit. If you look down carefully past the aft end of the port exhaust manifold you should be able to see the switch. I found that the Mercruiser part was actually less than an aftermarket. Go figure.
                    So I think it's too much fuel, not lack of. I just left the boat and was watching in the throat of the carb on the properly running engine and it has great atomization if the fuel. When I watch inside if the bad engine the fuel is dripping heavily into it and I believe flooding it below 2k rpm. Back probed purple power wire with it running and battery voltage present at all times when running. I think it's carb rebuild time.
                      You can swap carbs to see if it follows the carb but I think you’re right time for a rebuild
                        Yup, you have a sticky float valve. You might think about having both rebuilt. If you are in the Puget Sound Area, I recommend Carb Connection in Kirkland. They did the carbs on my previous boat and dialed in my muscle car resto-mod.
                          I already lost 1 weekend in our short boating season this year I am going to try to find a quality rebuilt one to just slam on and go and have the other one rebuilt and install it on the other motor. Any recommendations on who sells a good rebuilt one would be great.
                            So I think it's too much fuel, not lack of. I just left the boat and was watching in the throat of the carb on the properly running engine and it has great atomization if the fuel. When I watch inside if the bad engine the fuel is dripping heavily into it and I believe flooding it below 2k rpm. Back probed purple power wire for the fuel pump with it running and battery voltage present at all times when running. I think it's carb rebuild time.
                            Oops just trying to fix my post #10 from earlier
                              Is this your carb? https://www.i-5automotive.com/produc...rb-carburetor/
                              If yes, I have one I do not need: https://www.baylinerownersclub.org/f...-carb-for-sale
