2556 random projects 3/10 Bow thruster instalation
    I know one can manage without one, but for me this installation is mainly for safety but also for convenience. I do berth most of the time on holiday trips to rather tricky places, uninhabited islands using anchor and bow to a natural shore without any berth or marinas. So for safe " landing" its a great help to be able to keep the bow at place. And don't think my Alpha one can hold out to much prop walk rehearsals Click image for larger version  Name:	WP_20170820_14_48_54_Pro.jpg Views:	0 Size:	69.9 KB ID:	501131
    Bayliner 2556 1990 project
    And here some Click image for larger version
ID:	501141 more pics. Used a shallow drill so had to cut a lot during drilling. To keep the drill in place during operations made a support half way. The shape of the hole looks very strange when finally drilled.
      An then to the favorite hobby, sanding... Click image for larger version
        Then some cloth and core material to shape the area in front of the opening. Click image for larger version
          And then some more cloth. Only epoxy based products Click image for larger version
          To be continued........
            Great looking job!
            Mike & Dixi
            2006 265 5.0 MPI B3
            Closed Cooling
              Very nice job and glass work looks professional.
                Thanks for kind comments. I am just showing pics how have been doing the job, for sure there are more efficient ways for it. Still having a deep respect for the sea, for me its a matter of being comfortable with
                what have fixed, even if little too much work.....I have gain so much knowledge from this site that minimum what can do is to expose my own projects, maybe that is help for another member!
                  Great point of view, I have one question what DIA. is the tube in your installation?
                    140mm, this 2KW model.
                    https://www.lewmar.com/node/11697
                    It was some work also inside the hull to make space, to be able to laminate tunnel also from the inside. I had water trapped in the bow "compartment" so would have had to open and dry it anyway.
                    Here a picture when cutting the tunnel, pretty heavy laminate scheme in the bow area! And wood in the spray rail but that was dry.
                      Thanks, yes at times running a chop gun it will pile up, then it is up to the man with the roller to pack it in tight with out air bubbles.
                        A few more pictures, now from inside. I am glad i did laminate the tunnel rather strong already from the outside, from inside its hard....very hard at leas down under.... Click image for larger version
ID:	557647 . I mad a putty from epoxy resin, plenty of chopped strand, fumed silica and cotton flock. To get that smooth and even under the tunnel that was a messy job! Finalized with some cloth and epoxy.
ID:	557644Click image for larger version
                          Will paint the whole are with grey bilge paint including the storage space beneath the bed. When that's done will attache the thruster, that should not be hard....i hope.
                            amazing work! How did you figure out where to locate tunnel
                            1998 Bayliner 2858
                            7.4L MPI / Bravo III
                              To be honest, don't know yet is it located perfectly or not! But there are certain measurement mentioned in the installation manual( minimum length of tunnel, minimum distance to keel....) , and in addition to that searched the web for pictures on similar installations and further info.
