Can a solex 44pa1 be replaced with say a Holly?
    So I have a aq125 with a solex 44pa1 carb and I was wondering if I could get alittle bit more power using a little bit bigger carb without changing the intake so what carbs will fit the same bolt pattern as the stock solex? Or can this stock carb be redone at a carb specialist for more cfm
    use can use this, it's the only alternative I'm aware of: http://www.carburetion.com/Products/...aspx?Part=K861
    1986 2160 Trophy Hardtop w/ Alaskan Bulkhead
    VP AQ125B / 275
      I like the look of that but 750 is a lot for a small engine starting to wish I had a 350 sbc in my boat buy maybe I'll check local junk yards for a intake off a b21 engine that has a bigger card on it or I can manufacturer an adapter plate I did see some Weber knock off carbs on fleebay for pretty cheap
