Lower unit concerns
    Lower unit concerns
    Struck bottom last fall. We hit an unmarked rock at the mouth of a harbor. I have since learned that the harbors private owner has not maintained the entrance for years including not marking this obstacle. My B3 props are both being rebuilt, but the lower unit is making noises when put in either forward or reverse. Nothing huge, but something is wrong. We put on maybe 50 hours after the incident and the noise seemed to get a little louder. I will have it torn down and repaired this spring. Any idea what I damaged and what the repair will involve? Did I wreck a bearing, the u-joint or some gears?
    1999 Ciera 2655 5.7L BIII "Brenda Lou"
    1996 Skeeter 1850DV 175 Mariner 9.9 Mariner. sold, sold, sold
    1975 Lund 14' 25 HP Mercury. sold, sold, sold
    2008 Dodge Ram 2500 4x4 6.7L Turbo diesel Quad Cab
    Green Bay, WI on the Fox River
    South Bay Marina
    Since the noise is not present the upper half is ok with the unknown of the cone clutch however it’s most likely in the lower end gears or bent prop shaft.
      Agree with Mike. The prop shaft is likely bent causing a slight vibration and bearing failure. I’d check the shafts for runout
      "THE FIX"
      Misc. projects thread
        Thanks folks.
        South Bay Marina
          Have you considered making an insurance claim if you have insurance?
          Long Island Sound Region
            Seen twisted shafts, won't be known till teardown, take alot of pictures.
              Yes. I have started a claim. Thx.
              South Bay Marina
