PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
one seen this before - Hole appeared in Transom shield?
Hi Folks,
Has anyone a quick fix or do I need to have the transom assembly changed - very expensive in the UK (approx $5000).
Terry (Retired Diving Instructor and Part Time IT Consultant)
1998 Bayliner 2452. 5.7l V8 - Edelbrock 1409 4bbl - Alpha1Gen2 - Solent UK.
MMSI 235061726
Both of mine did this, Bravo 2's. When it was out for maintenance my maintenance/repair guy said it is quite common. He cut it out, cleaned up all the corrosion, and installed a piece of stainless over the hole.
sigpic
MDR3055
"GREEN JEANS"
'99 Bayliner 3055
Merc 5.0's Bravo 2's
Marina Del Rey, CA
Those drives are in salt as can be seen by the barnacles which is the worst place for drives. I have to assume a faulty mercathode system or worn out zincs or a combo of the 2 caused this. Bravo II have a really good reputation and this is definitely not common. That being said, fresh water bravos up here in never corrode, paint gets ugly after 10+ years but no corrosion. Heck the drives on my previous 97 Avanti still look great going on 22 years.
Cheers, Hans
2007 Carver 41 CMY
Twin Volvo D6-370
Montreal, Canada Midnight Sun I Photos
Your mechanic did you no favours, adding dissimilar metals especially stainless to a drive is asking for even more trouble.
Cheers, Hans
2007 Carver 41 CMY
Twin Volvo D6-370
The JR kit is basically what my guy did for the repair. They also use a SS plate for the cover. My zincs are kept up by my divers and replaced often. Mercathode is functioning. Thing is, that area is not submerged and sits out of the water. Any small wake, wind wave etc constantly splash up on this area and then dries. It's just a corrosion perfect storm. Had the repair done 3 years ago and still solid. Fingers crossed!
sigpic
MDR3055
"GREEN JEANS"
'99 Bayliner 3055
Marina Del Rey, CA
Is there enough "bite" left on the short side of the hole for the JR plate to work?
If I recall the plate in the kit only uses four screw, one in each corner. What you need to check is there enough material around the parameter to compress sealant between the plate and housing. Google the kit and review the instructions to determine for yourself.
That’s some nasty corrosion. I believe a custom stainless cover plate could buy you some time. Like Mike said you’ll need sufficient material available at the housing to hold the screws. I’d also recommend the use of marine grade urethane as the sealant, not a fan of sillycone in that application.
Thanks guys. I have a really experienced marine engineer who is going to take a look today. He will advise on whether a cover plate can be done or whether I need to Bring Out Another Thousand.
MMSI 235061726
It looks like this housing has been hacked on previously, not referring to the threaded plugs on either side but almost looks like it's been smoothed over with some type of filler then repainted in that area.
I agree with Dave. Looks like someone was using the Mercruiser kit to replace the swivel shaft and had issues so they opened up the housing then filled it over.
Hey, I just noticed that the swivel pin has been replaced once before using an alternate method I had done to mine. Check out the plugs on either side of the assembly. Check out the pictures again.
Simo
2002 2855 350MPI Bravo III on Lake Champlain -> SOLD!
Shameless lurking on Lake Keowee with a Harris Cruiser 210 Tritoon/Mercury 150XL EFI
