Cooling Hose - 2006 275 with 350 MAG MPI and Bravo III
    Got stranded because a pully was rubbing against a lower, starboard side cooling hose and blew a hole in it. We've tried getting it off, to no avail. Can't even get in there to get a picture of the hose so I can get a new one. So, at the risk of sounding like an idiot, can anyone help me identify which cooling hoses on the lower starboard side front of the engine compartment that could have rubbed against a pulley? Seems like such a simple problem, but we can't seem to identify the hose. Any thoughts? Thanks, John.
    Starboard side just behind the circ pump pulley? Sounds like it’s the return line from the cabin heater/water heater loop. 5/8 heater hose.
    "THE FIX"
    Misc. projects thread
      A picture is worth a thousand words...
      & always carry a rescue tape or two.
        For what it’s worth. I carry a good selection of pipe and tubing as well as a good selection of hose clamps. You can always cut a hose and clamp some pipe in to get you through the day. It came in handy on my old boats a few times.
        Currently watching from shore while deciding what my next boat will be !
          Closed or open cooling? What pulley; crank, circulating pump, ...?
