Winterizing the Boat
    I had my boat winterized while I'm away. The work notes
    said the pump didn't want to suck up the antifreeze. They
    manually drained and introduced RV antifreeze into the engine.
    Should I be concerned about this?
    1994 2859 in Tacoma, WA
    7.4 Mercruiser
    Still learning about other systems
    and specs.
    What method did they try that did not work? Place drive in a barrel filled with antifreeze, one of those winterizing kits that connect with muffs,...? If the latter these don’t always prime if the container is not up high enough and vented. How old is the impeller? You may want to just replace it and test the boat in the water in the spring.
      Thanks. Will do.
      7.4 Mercruiser
      and specs.
        Yes, you should be concerned! Sucking antifreeze up through the drive is risky. The risk is "dilution"!
        Please read my write up on this subject.
        https://www.amazon.com/gp/customer-r...at_pdctrvw_srp
        Rick E. Gresham, Oregon
          Rick: I hope the marine mechanic did it right.
          I won't be at the boat until about May.
          7.4 Mercruiser
          and specs.
            Sounds like they winterized in a manner that is best in my opion. Draining all water is the main thing...while I personally prefer adding antifreeze by direct pour like they did...some say this isn't needed.
            I like doing it for several reasons but that's another debate topic.
            I would much rather have them do as they ultimately did instead of how they first tried to winterize.
            I agree to make sure the impeller is working in spring but you good as far as winter protection. If it is close to time to change impellor...you may get that done and be done with it.
            2008 H210SS Four Winns
            Volvo Penta 5.7 GISX
            Prior: 1997 2050SS Bayliner
            Brad / Texas Gulf Coast
              Sounds like the way my mechanic does my winterizing so if done properly you will be OK.
              Rick Grew
              1981 Carver 3007 Aft Cabin
              2004 Past Commodore
              www.wrycc.com
                My 99 3055 did not have a drainplug nor does my current 80 Carver. One less thing to worry about IMO.
                Rick Grew
                2004 Past Commodore
                www.wrycc.com
                  Rick not sure how you posted this in two threads but its the wrong response in this one.
                  • 2850Bounty
                    2850Bounty commented
                    Hey Mike..... cut him some slack........ he's getting old!
                  [QUOTE=Nauti_Mike;n476018]
                  [/QUOTE
                  You got that right.
                  Rick Grew
                  2004 Past Commodore
                  www.wrycc.com
                    Not sure how it happened either. Sorry.
                    Rick Grew
                    2004 Past Commodore
                    www.wrycc.com
                      No problem. When I first read it I was confused until I saw the other thread.
                        Let me clarify my earlier comments!
                        I had my boat Engine winterized while I'm away. The work notes said the pump didn't want to suck up the antifreeze. They manually drained and introduced RV antifreeze into the engine.
                        For me, this would imply that who ever attempted to do this type of Engine winterizing (for jongleur), used one of the winterizing kits..... either Camco, Star-Brite, West Marine, etc.
                        Please.... if you have not read my write-up, please do so..... and read it twice if need be!
                        Correct! It is not necessary!
                        Pull each and every seawater drain plug......probe the open ports to clear them from any rust scale...... drain all seawater...... DONE!
                          Actually, I would be worried about the impeller in the pump. That was exactly how on my previous boat I found that my impeller is not strong enough. I tried to winterize my full system FWC by using muffs to suck the antifreeze from the hose in big plastic tank, and it did not work. In cold temperature the worn impeller vanes get stiff, break easily, and do not provide enough vacuum. I replaced the impeller immediately, and run about 4 gallons of the red stuff through the raw part of FWC.
                          Alex
                          1997 2859, 7.4 MPI, Bravo II
                            Originally posted by fishaman View Post
                            Actually, I would be worried about the impeller in the pump. That was exactly how on my previous boat I found that my impeller is not strong enough. I tried to winterize my full Closed Cooling system by using muffs to suck the antifreeze from the hose in big plastic tank, and it did not work.
                            Yep.... when the vanes (blades) lose their resiliency, they will not pump effectively!
                            This is why I remove my seawater pump impellers at lay-up time.
                            I replaced the impeller immediately, and run about 4 gallons of the red stuff through the raw part of the Closed Cooling System.
                            Yes... for a closed cooling system (better yet, a Full System), I have no problem with the winterizing kits!
                            It's the use on Raw Water Cooled engines where the problem lays!
