Is my Permatec aviation form a gasket still usable?
    Hi Folks,
    I am wondering if anyone knows how long aviation form a gasket will stay usable after being opened. The gunge looks fine and smells the same as it did 5 years ago when it was last opened . . . .
    I use it when putting the exhaust risers and spacers together after a strip down and inspection. New gaskets, form a gasket, leave overnight before starting. Just not sure whether I should buy some more form a gasket or trust the stuff I have.
    Thanks in advance.
    Terry
    Terry (Retired Diving Instructor and Part Time IT Consultant)
    1998 Bayliner 2452. 5.7l V8 - Edelbrock 1409 4bbl - Alpha1Gen2 - Solent UK.
    MMSI 235061726
    This stuff should be good that long, is it still semi liquid or all congealed?
    Long Island Sound Region
      It’ll be fine, stir it up a bit
        as long as its spreadable, its usable.... there are more adhesive types available from permatex if you feel the need to glue the parts together, but in my opinion, the only reason to use the permatex brand over a silicone gasket sealer is that the permatex products are more solvent resistant, such as when a sealer is needed where gasoline may come in contact with it.... silicone is oil and diesel resistant after it cures, but not resistant to prolonged exposure to gas.
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
          there is also supposedly a Permatex product that is a replacement for OMC gasket sealer which I use on all the bolts on the outdrive (impeller bolts, bolts that hold the upper and lower together, anode bolts, etc). It is not actually the Aviation sealer but a related product just don't know which one. But for most purposed the Aviation stuff is close enough.
            If it affects its ability to form a gasket, then it is not good. See how it spreads and if it's too thick and bunches up I wouldn't use it...
            One of the ingredients is alcohol...you could take a bit and add some alcohol and see if it thins appropriately (see MSDS)...
            I added some toluene and acetone to some vinyl cement and it brought it back to life (not suggesting toluene or acetone)...
            1988 3888
            Twin Cummins 6BT's 210hp
            Onan 8KW
              Does not melt as others will.
              Sometimes buying a small tube is a better buy then a larger size.
                Click image for larger version  Name:	Horton and the form a gasket 3 .png Views:	1 Size:	144.4 KB ID:	469782
                Update:
                Horton passed away earlier today.
                Doctors say that he died from complications due to a reaction caused by chemical incompatibility.
                RIP
                  Update:
                  RIP
                  LMAO...ur right...shudda been more specific...must have been the sugar in the Amaretto that got 'im...it's as bad as ice cubes with bubbles in 'em...
                  1988 3888
                  Onan 8KW
                    LMAO...ur right...shudda been more specific...must have been the sugar in the Amaretto that got 'im... it's as bad as ice cubes with bubbles in 'em...
                    Nick..... I was't making fun of YOU.... I just saw an opportunity for a funny!
                      ...I did take it as a funny...thanks...still chuckling...
                      1988 3888
                      Onan 8KW
                        Still liquid. Thanks.
                        MMSI 235061726
