2452 - Cranking and deep cycle batteries-gctid410265
    Hi everyone. One of my batteries is bad, so obviously i will replace it. Should I have a deep cycle for accessories and a cranking battery, or are two cranking batteries sufficient?
    Frankly I am not sure, but I beleive I have two cranking barrries now...Interstate 24MHD's.
    I like the idea of anchoring out and using a deep cycle battery to run the frig, stereo, tv, fans, fish finder, etc... and then switching to the cranking battery for the trip home.
    Thoughts are appreciated.
    howiet
    :arr
    Hi
    Many of the guys 'round here really like the 6V golf cart batteries. You need 2 of 'em, wired in series for your boat. These are reputed to be pretty good deep-cycle batts.
    I say that you need two, but I saw of the above mentioned batts at Sam's club - they're double high and 12V - that's what I will be getting, probbaly next year.
    Sarah
      Thanks Capt Sarah
        Hi
        I have two cranking batteries on mine, i use a smart alternator regulator
        http://www.sterlingpowerproductsbam....cts-altreg.htm
        All i have to do is put the battery selector to both or all and i never have to worry about selecting one or the other it's all done automatically.
        However if you are going to anchor and run the batteries down a lot then perhaps a third battery like Sarahs post topped up with a solar panel.
        Good luck.
          spike2450 wrote:
          Hi
          Good luck.
          I just threw in a dual purpose deep cycle (optima blue top) in as a starting battery, and also one as the house battery. I like having them identical (same chemistry) because the charger has only one switch setting for AGM/Gell/Flooded... wherever this switch is positioned, both batteries will get recharging treatment specific for that battery type. If I mismatch batteries, there will be charging issues. The dual purpose has worked great for starting, and good house capacity.
            Wet cell batteries perform a bit better for our HLBB (house load battery bank).
            You are correct. You'll want a dedicated cranking battery on #1, and at least one large Deep Cycle on #2.
            The 6 volt G/C batteries (in series) is actually a better way to go for your HLBB.
            More AH with these.
            Rick E. Gresham, Oregon
              The battery you describe is a cranking battery
              [img]/media/kunena/attachments/vb/714190=30771-24M-HD.jpg[/img]I have the 6V golf cart batteries and am very pleased with the results
                Cranking batteries are not designed to power a load over time and will deplete much faster than a deep cycle when powering accessories
                  I am going to purchase a deep cycle today and install it
                  Thanks everyone
                  Howiet:arr
                    If you have the space, consider two 6 volt Golf Cart batteries cabled in series.
                    You'll end up with more AH..... and Amp Hours is what we want.
                    More AH, and the less likely that you'll draw this bank down below 50%.
