Patching screw holes in fiberglass swimstep
    I need to move my davit brackets on my swim step, and that will result in the need to patch (or do I?) 6 dime sized screw holes in the fiberglass swim step. Any suggestions on resin or other product to use that may come in a small container?
    Johnson Point, Olympia, WA
    1989 2855
    Horizon 6.2 and Bravo II
    3M premium filler,
    marinetex
      West system make small pouch envelope containers for small repairs like this, but as Joon suggested Marine Tex comes in white and will blend in better.
      Gibraltar, Mi.
      1986- 3870- Hino 175's
      1988 26' Shamrock/ Diesel
      14' Zodiac Bay Runner
        Thanks folks
        1989 2855
          use a countersink to flare the edges of the holes to insure there is no small cracks remaining around where the old screws went thru the gelcoat, and then after filling the holes level with marinetex (or the west marine brand, MarineRX which is about half price of the marine tex) cover the fill with small pieces of plastic cut from a zip loc bag, and this will help allow you to level out the wet filler without getting it all over.... leave the plastic on til it hardens and it will peel off like a bandaid, leaving a smooth shiny surface on the fill that may or may not need additional fairing, depending on your desire...
          NU LIBERTE'
          Salem, OR
          5.7 OMC Cobra - 15.5x11 prop
          N2K equipped throughout..
            I use a white jb weld type product. You just break a chunk off and knead it then stick it in the holes. It’s like play do so it doesn’t dribble. They have it at Walmart, Home Depot, Lowe’s, pep boys, etc.
            Esteban
            Huntington Beach, California
            2018 Element 16
              https://m.youtube.com/watch?v=795hDUPSufg
              Esteban
              2018 Element 16
                Like Centerline2 says. Sometimes its also worth to re drill the hole slightly larger before patching, this way you get a clean fresh surface that will help bonding.
                Bayliner 2556 1990 project
                  Nice work men. I am on it.
                  1989 2855
