shift lever detent? dual lever Uflex B50 control, 2556
    do the shift levers in the late 80's early 90's dual lever controls that bayliner used, supposed to have a detent in the shift lever?.... if so, where is the detent mechanisim located?
    neither the upper control or the lower controls have a detent to indicate the neutral position, and my neutral lock out safety switch is commonly out of alignment when I go to start the engine, and would like to find a better solution to insure the boat is fully in neutral, both when running and when trying to start it....
    I believe it to be the U-Flex B50 controller...
    any suggestions?
    I have thought about wiring an indicator light into the lockout switch as an indicator when its depressed, but a detent would be better.
    NU LIBERTE'
    Salem, OR
    5.7 OMC Cobra - 15.5x11 prop
    N2K equipped throughout..
    The old Morse U-flex controls were problematic.
Name:	Morse U-Flex .jpg
    With an adapter base plate, the tried-and-proven Morse Twin S would be a great replacement.
Name:	Morse Twin S .jpg
    Your same 33C cables will connect up.
    Rick E. Gresham, Oregon
      There is a micro switch mounted to the frame under the shift lever. The shift lever has an arc to keep the switch open and a notch in the neutral position to allow the switch to close. Sometimes the shifter needs to be jiggled to get the switch lever fully into the notch, especially with dual stations. I find the lower station on Glauben to be more sensitive because the switches are on the upper helm and there is some natural play in the system.
      Some owners have enough issues, either because the switch fails or impatience at having to fiddle with the shifter every #$@& time, they bypass the switch. The danger in that is the risk of starting the engine in gear.
        this is the first boat ive owned with the U flex controls, but I have experienced the twin S controls in other boats, and as I recall they operate in a much better manner than the U flex.
        there seems to be nothing wrong with my U flex controls in as much as having a failure or being worn out, but they do seem to have more slack in the throw of the levers than any of the boats ive ran with the twin S controls in them.... maybe it was due more to age or care in the installation of the cables than the controller itself, but the twin S controls seem sturdier and more like a professional type controller.... WITH a detent for neutral.
        my U flex controls (throttle AND shift) operate easily and smoothly and identical at both stations, but both sides have a bit of fore and aft slack in them. when shifting from "in gear" to neutral, I have to over throw the lever so far that it seems like it should nearly be to the point of dropping into gear in the other direction.... but the cable housing is not moving when shifting, so the amount of slack in the is either normal for the U flex, or there is a problem with the linkage, or the lower shift cable is wore out..... I have looked at the controllers to see if any pins or pivots were worn, but there is no abnormal movement anywhere...
        but the controls seem to be dependable and and they arent stiff/hanging up, operating erratically or getting any worse, so maybe thats just the way they work...
        NU LIBERTE'
        Salem, OR
          yes, there is such a fine line in the shifter where the switch will allow the engine to start, and that is my real problem.... when trying to crank the engine, I have to mover the lever back and forth a bit to find the "spot", and with the key in the crank position, the starter will catch and then let go, catch and then let go, until I get centered on the sweet spot... its dependable but irritating.
          im not an advocate of deleting the neutral safety switch, BUT, Ive also had boats that WOULD start in gear, and I havent experienced any danger in it, although I can imagine a few scenarios where it could be very unsafe, and most of these scenarios include the lack of common sense ;-)
          NU LIBERTE'
          Salem, OR
            Should be a detent ball at the upper helm controller along with the neutral saftey switch.
            "THE FIX"
            Misc. projects thread
              Mine have the detent but in need of cleaning under the faceplate. It helped to adjust the detent spring tension but really needs cleaning underneath. My first few times with the controls was a bit difficult bringing her into the slip...got over it. When cleaned, they should react much better...
              Plastic adjusting screws on the side helped./..
              1988 3888 "Liberty"
              Twin Cummins 6BT's 210hp
              Onan 8.0
              Boating Raritan Bay
                is the detent under the face plate, or is it in behind the plastic friction screw in the side of the pivot cover/faceplate?
                NU LIBERTE'
                Salem, OR
                  Detent ball is underneath. The friction screw is just a friction screw. I'll snap a pic in the morning if ya like
                  "THE FIX"
                    Here’s a pic looking up at the bottom of the controller (shift lever side) There’s a plastic piece just above the neutral safety switch that houses the detent ball and a screw (hard to see) that will adjust the tension to it. Click image for larger version  Name:	4BA2F5D7-2C55-4E7D-A293-78E57E13AC19.jpeg Views:	1 Size:	296.3 KB ID:	447975
                    "THE FIX"
                      thanks... the photo helps a lot.
                      NU LIBERTE'
                      Salem, OR
