I am asking for advice on adding an inverter system to my 1993 2959 Classic. The boat did not come with a generator and I would like to add an inverter sytem, not just a stand alone single inverter. Does anyone have any experience with this task?
AC Power-gctid348994
Dave, you'll find that many of us use inverters and many of us use Charger/Inverters.
Xantrex offers a Freedom series Chrg/Inverter that interfaces with their LINK battery monitoring systems.
You'll also learn that in order to use an inverter efficiently, our HLBB's will need to be fairly large in terms of Amp Hour capacity.
Even with large capacity, we have limits as to how far down we can draw the HLBB, and limits as to how long we can go without re-charging.
Inverters are not necessarily very efficient when turning 12 vdc into 120 vac.
Since Engine Alternators are not ideally efficient at re-charging, and since you do not have a generator, you will be even more limited.
I would recommen that you calculate your daily anticipated Inverter loads on the House Bank, and in Amp Hours, and decide from there which inverter suits your needs, and then size of you HLBB accordingly.
But do not leave out a means of re-charing.... or you may end up replacing batteries more often than need be.
Harv has a thread in the BOC Library that would be good for you to read.
Rick E. Gresham, Oregon
There are a dozen multi-page discussions on this topic just from the past year. Do a search, be prepared to read a lot, and then if you still have questions, ask them in one of those threads or here.
Oh, and I have both an inverter and a generator. One doesn't necessarily make the other not necessary.
I purchased my inverter from Harbor Freight, 1500 watt continous, 3000 surge, used it for my 7 cf freezer, has worked for 3 years now, no issues, they have one larger unit, resonably priced, $129.00-$169.00.
