Ruined my perfect day yesterday. Coming back to the dock I always cut in, wife jumps out with bow line and I hit reverse and swing the back in. This time motor died and I hit the dock and than cement seawall in front of dock. Just damn glad wife did not get hurt. Wind was from the stern and the boat just kept going forward. At least bottom did not hit the ramp. My first scrape in 8 years, time to brush up on gel coat repair. Anyway boat will not idle but runs fine at fast idle. Got on line and several talked about the IAC valve will effect idle and I also had a two beep alarm per minute. I crossed referenced the mercruiser part number over to an automotive valve AC423. Picked one up at auto zone for 1/4 price of mercruiser and that was the problem. So far on the muffs it is running fine at idle with no more double beep per minute. Certainly hope that was it and not something else that will come back. Usually the ramp is busy buy it was empty so I just came right in. Learned one lesson, I will always check idle before before moving in to dock. I was only about 800-900 RPM with a cross wind and the 289 just kept going.
Rock
Rock
