Bayliner 2002 2125 Cuddy where to install in-hull transponder-gctid406775
    Where is the best location on the 2002 2125 Cuddy to install an in-hull sonar transponder?
    The best place is to the right of the centerline in the engine compartment between the structural rakes. You have to use epoxy and get the sensor level with NO AIR in the epoxy bond. Otherwise the thing will be reading out to the side of the boat. Mounting in front is OK but you have trouble with leveling.
    David
    http://www.cambridgeadvertising.org
    http://www.davidladewig.com
