Thunderbolt Ignition trouble shooting
    Engine won't start, very weak and no spark at times, 4.3 gen+, I think it's the sensor, module or coil. I once downloaded a trouble shooting guide to figuring this out, do you think I can find it? If anyone has a link I would apreciate it.
    Trophy WA 2052 4.3 Mercruiser Alpha 1 Gen II
    Maple Bay, BC.
    Here is what I used to find the issues I had with ignition sensor under Distributor cap . Think it is also in the Mercruiser shop manual
    https://www.boatdesign.net/attachmen...24-pdf.134493/
    2004 Trophy 2359
    5.7 liter Carb
    Alpha
    15 hp Merc Kicker
      Thanks ardoski14 for that it has that info-graphic that I once had, I will file the pdf in the proper place this time.
      Maple Bay, BC.
        there are 3 wires going to the distributor sensor. there's a 12V hot; the "signal" wire and a ground. Separate the sensor wire from the distributor, and scrape it along a ground. I think its the green white wire. If it sparks, replace the sender. If not then its the coil or the module. In order of cost: the module is costly, next the sensor at about 125 (last time I bought one) an the coil is cheapest.
        A word of warning: The module and coil are designed to work with each other, with turns ratio, resistance, etc. An aftermarket "auto" coil will not work. I even tried a NASCAR grade coil. Spend the $85 and get the right one. I am 71 yrs old, and 1 thing I learned from life: anytime you try to cut corners and substitute, it will cost you more in the long run, because it will come to bite you in the ass.
        Captharv 2001 2452
