Nauticus Smart Tabs-gctid406288
    Hey all,
    I was wondering if anyone has ever used the Nauticus Smart Tabs? If so, what did you think of them? I have a 2000 model 2050 LX with a MerCruiser 305 with an Alpha 1 sterndrive, and I was thinking about adding them to help with porpoising when I'm on Lake Tahoe. The water gets a little choppy in the afternoons.
    Not familiar with that brand, but the guy from Bennett Tabs is here all the time answering questions and providing top notch support. I have them on my boat and they have been great. Based on my experience and the level of support I would not buy another brand.
    At least check them out as an option.
      I installed smart tabs on a 2008 192. Greatly improved porpoising on choppy water. I also found that it improved performance with bowrise when planing out and I noticed a definite improvement in slow speed wander. Very pleased with them.
      FNT
      2008 Discovery 192
        I installed Smart Tabs and what FNT said, faster on plane, less bowrise, less porpoising, less wander at slow speed and best of all $100 and self install in less than an hour.
          Thank you everyone for your quick replies. I really appreciate it.
            I installed the SmartTabs SX with 40lb actuators and PR500 top brackets on my 1952cn Cuddy. I got the PR500 brackets so the tabs can be stored in the flush position so as not to interfere with the lift at my High-Dry storage marina. I am pleased with the improvement. Slow speed wander is 90% eliminated, boat planes faster, rides smoother in chop. You can still use the trim adjustment on the outdrive to further adjust the trim. My boat calls for the 60lb actuators but I didn't want to overdo it so I went with the 40lb.
            1996 Donzi 275 LXC
            7.4 Merc Bravo III
            Home Port Tarpon Springs, FL
            Previously:
            2002 Bayliner 1952 CN Cuddy
            Way Back When:
            1969 Slickcraft SS170 / 1971 Johnson 125
              I installed some on a 14' Sea Ray SeaRayder I used to own. The boat had a terrible engine and a pretty flat hull, so planing was hard. I installed what the folks at Nauticus recommended to me and I thought they worked great!! After a few adjustment runs, I was planing quick, my control was better and less wander at slower speeds. PLUS, no switches or electric to deal with! Good company to work with too~!
                Mike, your boat size/length is right at the limit (perhaps a bit past) for smart tabs, IMO.
                The Bennett hydraulic TT's may serve you better in that they offer full control from the helm.
