I have a 1996 2252 hardtop with a 5.7 Mercruiser with an Alpha 1 gen 2.
Previous owner had the engine rebuilt and it had 25hours when I bought it. It currently has 55hours.
Im trying to figure out why Im not getting good mileage or performance.
On a 60 mile roundtrip a month ago I calculated about 1.5 mpg cruising at about 30mph, which I think was about 3200rpm. (topped off before going out and again afterwards, so I knew my quantity of fuel burned). I also top out at 35mph, alone.
This weekend I noticed fuel dribbling in the carb throat when idling so I switched the link position on the accelerator pump arm link and that got rid of the dribbling, got rid of my hard starts when cold, but now I only top out at 32mph.
Not much info related to these specific boats can be found, but on one boat test they were able to do 40mph, with the v6. So i expect better than that.
Anyway, to my question.
Current prop appears to be a 15.25 by 15p (cast in so it is not to legible) with a 2008 and other markings. Quicksilver lists a 2008 partnumber as a 15.5 by 15p.
The Bayliner parts website lists a 14.5 by 17p prop as standard equipment.
Is the 15.25 by 15p a "bigger" prop than the 14.5 by 17p?
Is the pitch the distance to complete one turn?
