Getting OMC Cobra Bellcrank to 90 Degrees-gctid405762
    I replaced my transom bracket shift cable and am curious about getting the bellcrank to 90 degrees. I have the 6 1/2" measurement at the engine for the trunnion to the shift lever already. Does the 90 degree go to the top of the bellcrank? It seems tapered on the top and bottom so it seems that 90 degrees to the top wouldn't be right. Is it 90 degrees to the centerline of the bellcrank lever? I am hoping someone has a better diagram than what is in the manual to be able to see where the 90 degree line is.
    Thanks in advance.
    90 degrees to the center line of the bellcrank lever. The best pic/description is item #53 on page 11-11 and 11-12 of the manual.
