I will try to make a long story short.
Boat 2252 Ciera Classic year 2000
305 Mercruiser Alpha One Gen 2 Raw Water Cooled
Starboard side riser always hotter then the port side.
Had the boat since 2004 and to my knowledge the manifolds and risers have never been changed. I planned on doing it at the end of this season but have run into temp problems. Last year I changed the water pump, this year before I put her in I changed the impellar. I have been out 2 or 3 times a week since June. The temp has always been steady at just under 170. The boat sat for a week and I decided that since I was going to Florida for a week I wanted to run her good to try and clean her bottom. Well after running for about 15 to 20 minutes at about 4000 rpms I saw the temp gauge begin to spike, it almost hit 200. I backed off the throttle and it dropped quickly. I slowly opened her up again and the gauged climbed but not as high as before but still higher than normal. I eased it back down to about 3000 rpms and she seemed to run at a steady temp but higher than normal, 175 or so. I could see the gauge flucuate when the Tstat opened and closed. At lower speeds everything pretty much seemed normal. Came back from Florida a week later and took her out today. She seemed to be running a little hot then at one point the the temp dropped like a stone, then rose a bit, then she went back to running about 175 to 180. Again when running at lower speeds all seemed normal. I am thinking that I have restricted water flow through the system. I am attributting the temp spikes to pieces of crude from the risers and or mainfolds blocking more of the passages and then freeing themselves. After I got home I spent the better part of this afternoon reading the riser and manifold threads. I read the thread about loosening the bolts while the motor is hot so I went out to give the bolts a once over. They are all easy to remove. Now I have been shopping aroung for mainfolds and risers. I found this place from one of the posts http://www.mercexhaust.com/
The prices seem very good for both the osco and the mercruiser replacements. I am going to replace the t-stat tomorrow and order the manifolds and risers. Even if the T-stat turns out to be the problem 11 years on the manifolds and risers is way past the experation date. My questions are....
1) Could I possible be missing something else that could be giving me this problem? Such as a bad guage or some form of flapper valve.
2) Are after market risers and manifolds ok to go with or shoulf I stick to OEM?
3) Does the type of gasket matter?
4) Since I will have the manifolds out what else if anything should I change? Spark plugs come to mind, anything else?
I plan on going with the plank across the gunnels and winch strap idea and using anti-sieze when I reinstall the bolts, Thanks for reading and adding any tips or suggestion.
