Water in Bilge-gctid405572
    After first launch this year I noticed water in the bilge. I suspected that it was rain water that somehow found it's way in, (lthough this has never happened in the past) so drained it out when I had the opportunity. I recently launched and moored in salt water for 3 days, and again had bilge water (about 1"). It was salt water. I know it's not the bung, it's solid, and well sealed. Another Trophy owner at the marina mentioned that it was likely the seal behind the gimbal bearing. This didn't make a lot of sense to me. I'm going to do a dry run tomorrow on muffs and rule out any hose leaks , etc. Is there any specific area that I should be looking at? I've nver experienced a leak in this area before.
    Bob Hawes.
    Kelowna, B.C.
    1998 Trophy 2052 WA
    4.3 Vortec, A1 G2
    How long since you've had a Bellows kit installed? Those leaks usually come from a bellows, not the transom seal.
    David
    http://www.cambridgeadvertising.org
    http://www.davidladewig.com
      I've only had the boat for 3 years, and it's a 1999. I doubt that they've ever been changed, but they look like new. I only put about 25 hours a year on it, and I don't think that the previous owner even put on that many.
      Bob Hawes.
      Kelowna, B.C.
      1998 Trophy 2052 WA
      4.3 Vortec, A1 G2
        It is not the hours of the engine use, but the years of their age that deteriorates them. Most DIY'ers change them every 2 or 3 years.
