Hello fellow boat owners. I have recently purchased a 2002 2052 WA and I really like it! There are two issues that I'm hoping to get some help with:
1. The previous owner covered the scuppers because of the issue with water backing into the fishwells. I know this is a common issue with this boat and I want to replace the scuppers with Rabud's. My question is ...what size do I order? On the website, I only see 1" and 3" scuppers. Mine appear to be somewhere in between. How exactly do I measure?
2. The drain hoses from the fishwells were taken out from the back so that they drain into the bilge. The pumps seem to still work and I'd like to reconnect them. I can't figure out how the threaded tube on the hose attaches to the hole in the bottom of teh fishwell. Is there a flange that threads on from the inside and is then tightened with the nut from the outside?
Thanks for reading!
-John
New Baltimore, MI
Thanks for reading!
-John
New Baltimore, MI
