When a boat is re-powered upward as this one is, I am assuming that the stern drive must also be upgraded? The original stern drive lower unit is 1.84R (sn: 0D730874) which is still on the boat, and the boat has sluggish response in the water.
Questions: I am assuming that I will need to change the stern drive lower unit to 1.50R, which is what a 350 would require? If so, can I use the old stern drive upper unit or do I need to replace it as well? What about the prop?
Thanks for your help.
