help please-gctid404611
    Hi'
    Need help please my Bayliner 2355 Ciera Has a fuel leak it looks like it my be from the under floor fuel tank .
    how do I remove the tank do I have to cut the floor out?.
    cheers
    Les
    Before you remove the tank why not pressure test it to make sure the leak is from the tank???? Remove the vent, fill line and fuel line and plug the fittings on the tank, put 3 pounds of air in the tank and let it set, if it looses any pressureand your plugs are not leaking you need to pull the tank....
      Cheers I will give it a go
        Please look at my post in "2355 owners" I've just had the same problem....
        Let me know if it can help you!
        Grtz from holland
