When I first start up the generator on my 3055 (Westerbeke) it blows the 8amp fuse after a few minutes. Then, it blows the fuse everytime I try to start it. Anyone have any ideas as to what might be causing this? Thanks. Tim
Generastor Issue-gctid404165
What size generator is it? The 3kw westerbeke gasoline genny has a 10Amp fuse for the control circuits and a 20Amp fuse for the battery charging circuit. Maybe someone replaced the 10A with a 8A, which could be a little too small for the circuit. Do you have the manual?
http://baylinerownersclub.org/media/...nout.gif[/img]EDIT: I realized the diagram didn't actually have the 85/86 labeled. So they are the unlabeled pins on the left and right.
