Hello,
Boat- 85 ciera2450 AQ225d 280sp
Long story short, i spun my old prop, which is stamped with part # C850864. That part number has been changed to 854983, which is a 15" dia. 19pitch left hand rotation...
So being a frugal fellow, I ordered a MUCH cheaper solas amita 3 e-plus prop with those specs... (btw, the eplus says the large blade design is for large/heavy boats) Unpacking the new prop, I noticed the blades are significantly smaller than the original. I ran it at the lake this weekend and the performance was terrible. The new prop has nowhere near the "bite" of the original and the boats struggles more than usual to get up on plane. Slow speed performance is worse also.
I guess i'm going to have to just breakdown and buy the OEM replacement and keep this as a spare. Although, there has to be a non-OEM option out there....
Anyone else had issues like this?
If you have a similar boat, what prop are you running?
