Wiring Harness for Bayliner Capri-gctid403950
    I need to find a complete wiring harness for my 1986 bayliner capri it is 19' has a AQ131 Volvo Penta and a 275 Volvo outdrive. Thank You for your help
    To wire the boat or the harness on the engine?
      complete dash to engine. Thanks
        You may not have to limit your search to the exact same boat nor year model. The main hull harness may work from another similar hull, as long as it's for the Volvo Penta engine.
        The engine harness for many of the OHC 4's in this year range, is pretty much the same.
        Try a boat salvage yard. They parts these boats out, and may have something that will work for you.
          There are so few wires involved. I would tend to just rewire it myself.
