my 1991 bayliner Capri only has half power-gctid403942
    Sometimes it will go 32 mph and other time 15. It is a L drive force motor. the boat has been taken care of and the motor is clean.
    engine bogging?:
    I'd probably start with a spark tester and make sure you are getting strong spark on each cylinder, then move on to fuel supply (pump and any in line filter), and compression test the engine
    engine revving high, but no speed?:
    try another propeller
