94 4.3 lx mercruiser shift cutout-gctid403859
    When I have the shift cutout hooked up it kills the engine when I shift into gear. If its in gear and I hook it up it kills the engine. Any ideas? Thanks!
    I think that you're talking about Merc's SI system. SI = shift interrupt.
    The SI is to aid in a shift from gear, back into neutral.
    It should NOT be stalling the engine while making a shift into gear.
    Sounds like you need an SI adjustment.
      Yeah I'm sure that's what it is. I thought it was called shift cutoff or cutout. Any idea how to adjust it?
        First off, the adjustment must be done while the boat is in the water. We need to create the prop thrust that prevents the Dog Clutch from disengaging easily.
        If you've not done this, you may want to have a Merc Tech do it for you.
        BTW, shifts must be made quickly and decisively.... no fooling around, or even a well adjusted SI will stahl the engine.
          Thank you! I may just have my boat guy do it.
            I'm a little hard headed when it comes to taking stuff somewhere to get it fixed..... I like to figure things out. But this may be easier taken to someone. Thanks again!
              I think that is a good attitude. It will help you if you were to have trouble while out on the water.
              Have someone make a shift while you watch the SI system... engine off and boat out of the water for now.
              You may need to hold resistance on the Dog Clutch via the Propeller.
              You'll see that the lower shift cable outer jacket resistance moves the cam lever arrangement.
              As the cam lever moves, the micro switch is activated.
              It's fairly easy to figure out once you see the parts in action.
              Give it a shot...... you really can't screw anything up that can't be easily corrected.
                Sounds like shift cable sticking to me . Everyone i saw do this adjustment worked once and a while .The cable starts sticking holding the switch too long ,killing engine .
