I am wondering how many of you have had the awful experience I have had with the Mercruiser hydraulic tilt rams? I had my last boat, a 2000 2452 with alpha drive, for 5 years. During that period I had to have the seals in the back of the rams replaced twice. The tech here tells me the salt is responsible for it, the seals get corrosion behind them and swell to the point that they bind up the ram. I could see the effect on the last set, the stainless steel around the seal begins to rip away from the seal in response to the swelling. Last time I had them rebuilt, they said the tool that is used to open the end of the ram would not work and they muscled it off with pliers and pipe wrenches!! Obviously the chewed up the end and the housing, then told me it was the only way to do them. Well that boat is gone, now on the "new" boat, 2004 288 I have a BIII drive. Yesterday I was over to the boat to change my "zincs" (aluminum) and when I pulled the anodes off the end of the rams I could see the same thing taking place on these, and I can not turn the piston when disconnected from the drive, which is what the last guy told me was the symptom of this problem, and sure enough when I put the rams back on the drive it will not go up or down, although the pump is running. I know it is the same problem.
Now the heart of the question, I have the option of getting these rebuilt again, to the tune of a hundred or more per unit, or I have found online that SEI sells new ones for $120 each. I would rather have new, but am not familiar with these. I generally try to stick to OEM parts but thinking I dont have much to lose here, as I will still have the old ones if I need to get them rebuilt. Anyone have any experience with this company? I see they make replacement lower units for outboard and Alpha drive units with "3 year no fault" warranty. Seem silly to keep getting the old ones redone if I can get new for $120 per. Whatdaya think???
