Transducer to 3055-gctid403815
    Hi, I need to fit a Airmar TM260 1kw transducer to my 3055. Any ideas for a prime location as it seems a bit limited to me. I am hoping that one of you have been there done that before. At this stage I am starting to think that maybe I should have bought a through hull unit. Although I also have to mount the transducer for the StructureScan and I seem to recall being told that the two transducers need to be quite close to allow map overlaying, which couldn't be achieved with a through hull unit, due to the distance between the transducers. I need to get this sorted so any help would be appreciated.
    Maybe this will be of value. We have a 305. I posted the below.
    Jim McNeely
    Twin 5.7s with Bravo2 drives
    Brighton, Michigan USA
    MMSI # 367393410
      Although not as complex as Jim's, mine is also mounted in the same spot as his.
