prop suggestions-gctid403780
    i have a 1987 ciera 25ft with a omc v8 rated at 260hp i was wondering what would be a good prop for fuel economy without sacrificing fuel economy.
    Is this a Jedi mind trick question? I think you meant performance without sacrificing fuel economy? If so give us your current specs: prop size and pitch, cruising rpm/speed, wot rpm/ speed and how heavy do you usually run.
    Without this info anything is a guess but hey I'll bite try a 15.5 x 15 four blade power tech if you run heavy, 16 x 17 three blade if you want more top end speed and less lift at cruise speed.
