Hino EH700 175HP
    Hino EH700 175HP
    Hino EH700 175HP – Oil Filer.
    Help, I like to buy the correct metric wrenches and to avoid using an adjustable crescent wrench.
    Question what are the sizes for the long bolt that goes through the center of the filer and bottom drain plug bolt sizes?
    I bought a set of new Oil filters from Lordco but there missing the rubber O rings for the drain plug, what would the size be a that also.
    Payback.
    I bought a set of metric combination wrenches and sockets from Harbor Freight. They do most everything I do on the my EH700s. I have a similar set of inch standard for other equipment on the boat. If they rust up, they are cheap enough that there is no great loss. I cut up a 1 gallon plastic milk jug so the oil from the filter housing would drain into it. Be sure to clean the spinner too.
      .Thank you, Pete, for your thoughts.
      Today I picked up a full set of SEA and METRIC box end ratchet wrenches from Canadian Tire. -60% OFF Saved $ 150
      [COLOR=#3C3C3C][FONT="Segoe UI Emoji"]
