New Distributor
    New Distributor
    Since I'm going to be tearing down the top end of my motor (water in #7 thread) I got to thinking this is prime time to upgrade the distributor to from points. Looking for suggestions and opinions or sources for getting one. Thanks to all.
    Ted G
    The Great PNW
    86 2850 Contessa SB
    Designers Edition
    Mercury 350 Mag
    290 Volvo DP
    Mallory makes a nice unit that can be bought as a kit with coil and wires for a reasonable price.
      Just a thought: If your distributor is in good operational condition (no sloppy bushings etc.) you could go the simple route, low cost and just replace the points with an aftermarket triggering system.
      "THE FIX"
      Misc. projects thread
        IF the bushings are tight, I agree with Builderdude.... get the numbers off of your distributor and check to see what pertronix conversion kit you need for it, and check it against the price of a new, fully loaded distributor....
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
          Michigan motorz sells a nice upgrade, whole kit ...
            I'd forgotten about pertronix and I actually went that route n my 2555. I'll check the original out and go from there. Thank you!
            Ted G
            The Great PNW
            86 2850 Contessa SB
            Designers Edition
            Mercury 350 Mag
            290 Volvo DP
              I have Pertronix in my 290 hp crate engines, they work great.
