Westerbeke 8kw run without cooling?
    Can i start my generator without seawater cooling? I mean now that my boat is docked i would see if the generator works and starts, just for a few seconds?
    New owner of a 3270, 2xHino 135
    If it has closed cooling, running for a "short" time would be fine. Be sure the impeller is removed.
      Thanks,i thought so too but... Yes,its a closed cooling and impeller will be removed.
        why being docked would prevent raw sea water from being used for cooling??
        Started boating 1965
          Maybe i used the wrong word, its out of the water for winter (docked?)...
          • Nauti_Mike
            Nauti_Mike commented
            On the hard is the proper terminology
          Perhaps use a garden hose.
          If not make the check short - it does not take too long to melt the exhaust hose etc.
            With or without the impeller, I would be concerned about dry running the pump and damaging its bearings and spindle. Much better to stick a garden hose to push water through the system.
            bdervisoglu8@gmail.com
            bulent@pacbell.net
